Duckdive
Sep 18, 2015Aspirant
REDUCED WIFI SPEED with NETGEAR R7500
I am having troubles with my NETGEAR R7500. I upgraded to 110mps speed by am only getting speeds of around 54mps.
Duckdive
Sep 20, 2015Aspirant
I have Wide Open West internet with 110mpbs
My lap top has Qualcomm Atheros AR956x wireless adapter. When i connect using cat5 cable i get extemely high speeds on test but i keep dropping off interent. As for the two computers, they have USB Realtek RTL8192CU 802.11N adapters.
Thank you for your assistance.
TheEther
Sep 20, 2015Guru
It's hard to find information about the Atheros AR956x, but it appears to be a single band (2.4 GHz only), single stream 802.11n Wi-Fi adapter. When using 20 MHz wide channels (very common with 2.4 GHz Wi-Fi when other Wi-Fi networks are present), the maximum link speed possible is 72.2 Mbps. Real world throughput will probably be in the 25 to 35 Mbps range. If no other Wi-Fi networks are present, then you may be able to use 40 MHz channels and a link speed of 150 Mbps. Real world throughput will be 50% of that or less (75 Mbps or less). But I wouldn't count on being able to use 40 MHz channels with 2.4 GHz Wi-Fi.
The Realtek RTL8192CU adapters are dual band (2.4 GHz and 5 GHz), dual stream 802.11n Wi-Fi adapters. These should be able to connect at a link speed of 300 Mbps at 5 GHz. Again, real world throughput will be 50% or less (150 Mbps or less).
With respect to the R7500, you will want to make sure that WMM is enabled. Without it, Wi-Fi will slow to a crawl. The other QoS functions, like upstream and downstream QoS, can remain off. Since you have pretty fast Internet service (120 Mbps), you probably won't benefit from QoS, so I recommend that you leave upstream and downstream QoS off, but feel free to experiment.
