JimmyW's avatar
JimmyW
Luminary
Mar 19, 2019
Refresher on firmware updateand downgrade
I'm running firmware V1.0.9.42_10.2.44 on my R7000, and  I thought I'd update to v1.0.9.64.  I've backed up my settings.  Should the update prove unwise. I thought I'd restore my present firmware, but where is the link to download V1.0.9.42_10.2.44?  Second, is there a recommended procedure to install the update, such as a hard reset of the router before updating?  After I update, can I use my exported cfg file (from my V1.0.9.42_10.2.44) to set the config of the new firmware?  I shouild point out that the router works great (on the high band) with the current firmware, so is there a good reason to update, such as security patches, etc.?  Thanks!
  • JimmyW wrote:
    At this point, a hard reset of the router is not indicated, so I'll forego that option for at least the time being.
    That's the way to do it. Resets are there for sticky situations. Avoid when possible.
    • JimmyW's avatar
      JimmyW
      Luminary
      Thanks for the suggestions and links.  I updated and suffered no ill effects.  After a few pc reboots, all is well, and my d/u speed remains at 100+/11 Mbps (Spectrum), with no connection issues on the network.  At this point, a hard reset of the router is not indicated, so I'll forego that option for at least the time being.
      • michaelkenward's avatar
        michaelkenward
