huttler
Nov 26, 2017Aspirant
Remote Access Problems
Problem: unable to access router while away from home Reason: The remote management address in the router setting is stuck on IP address 192.168.x.x I was able to use remote access when the rout...
- Nov 27, 2017
Hi huttler,
Set the modem to bridge mode to make sure the IP that the router gets is private.
JamesGL
Nov 26, 2017NETGEAR Employee Retired
Hi huttler,
Make sure that the router is not connected to another router. The IP address should be a public. What you have is a private which means the router is connected to the modem/router device.
