huttler's avatar
huttler
Remote Access Problems
Problem: unable to access router while away from home Reason: The remote management address in the router setting is stuck on IP address 192.168.x.x   I was able to use remote access when the rout...
  • JamesGL's avatar
    JamesGL
    Nov 27, 2017
    Hi huttler,
    Set the modem to bridge mode to make sure the IP that the router gets is private.
