westewart
Jul 04, 2022Aspirant
Remote Access to LAN R7800
Hi, I am concerned about remote access to my LAN. I have not noticed anything, but for the 1st time I just looked at my router log and saw the following: [DoS Attack: ACK Scan] from source: 159.10...
westewart
Jul 05, 2022Aspirant
Hi MircroChip8,
I need to do remote work, so how can I access my server more securely?
Netbob
Nov 27, 2022Aspirant
just a quick note, instead of turning on remote mgment on your router, create an internal vpn (on the router or my preferred way, on a spare raspberry pi) that way you can start a vpn session from wherever you are and to your router, you are local.)
hih, nb
