Zuek's avatar
Zuek
Follower
Oct 10, 2016
Remote access with own domain
I have a router, a static IP and domain (let it be a domain.ru). I want to use subdomain router.domain.ru to access my router. How I can do it? I create A-record (@ and router) at domain DNS and point it to my IP. If I enter domain.ru - I can access router. But if I enter router.domain.ru - I couldn't. How to make vice versa?
  • Hi Zuek,
    This might not be possible with the router. The router will only read the domain to access your router based on the configuration in DynDNS.
    JamesGL
    Community Team
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Zuek,
    JamesGL
    Community Team
  • JamesGL's avatar
    JamesGL
    Hi Zuek,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    JamesGL
    Community Team
