ae6dx00
Apr 04, 2020Guide
Remote management address
Where is the remote management address set? On that screen I just see it listed http://<myname>.mynetgear.com but no place to change it. When I try to access that address my broser says the securit...
- Apr 05, 2020
It worked in Safari
ae6dx00
Apr 04, 2020Guide
Here is what I' refering to https://kb.netgear.com/23860/How-to-Setup-a-NETGEAR-Dynamic-DNS-account
When I visit the DDNS link to go to my router I get the attached screenshot.
michaelkenward
Apr 05, 2020Guru - Experienced User
That is probably your browser objecting to what it sees as a security lapse.
What happens with a different browser? Most will have a link that you can click.
For example, here's what I see in Edge:
Chrome has a similar "Get out of jail" link.
- ae6dx00Apr 05, 2020Guide
It worked in Safari
- michaelkenwardApr 06, 2020Guru - Experienced User
ae6dx00 wrote:
It worked in Safari
Good feedback. Browser related then.
It might help if Netgear got to the bottom of this and provided some sort of fix.
