Faccin0
Jul 01, 2019Guide
Remote Management issue
hello everybody, I'm tring to use the remote management but I'm having issue with the configuration. So this is what I did: - created a domain *.mynetgear.com to use DDNS - activated the remote...
- Jul 01, 2019
What always works is the App based (Nighthawk App, Genie desktop App) remote administration access which does not require a public IP direct on the router. Limited functionality, but better than noting.
schumaku
Jul 01, 2019Guru - Experienced User
For the remote management your router needs a public IP address on it's Internet/WAN interface - without an additional NAT router (e.g. your ISP one) in front of it - or have some port forwarding configured on that ISP router for the Netgear router remote access port.
Don't see on how a PC on your local [W]LAN with NordVPN up should have an impact - confirm NordVPN is configured on the computer, not on the router.
- Faccin0Jul 01, 2019Guide
Yes, NordVPN is configured only on endpoint and not on the Router. In any case I think I can't fix the issue because I don't have access to the ISP router to change settings or forward the port.
Thank you for your answer!
- schumakuJul 01, 2019Guru - Experienced User
The app doesn't work but my phone has also some network problem and I'm replacing it. Maybe with the new one I will be lucky!
Thank you very much for your answers!
