Faccin0
Jul 01, 2019Guide
Remote Management issue
hello everybody, I'm tring to use the remote management but I'm having issue with the configuration. So this is what I did: - created a domain *.mynetgear.com to use DDNS - activated the remote...
- Jul 01, 2019
What always works is the App based (Nighthawk App, Genie desktop App) remote administration access which does not require a public IP direct on the router. Limited functionality, but better than noting.
Faccin0
Jul 01, 2019Guide
Yes, NordVPN is configured only on endpoint and not on the Router. In any case I think I can't fix the issue because I don't have access to the ISP router to change settings or forward the port.
Thank you for your answer!
schumaku
Jul 01, 2019Guru - Experienced User
- Faccin0Jul 01, 2019Guide
The app doesn't work but my phone has also some network problem and I'm replacing it. Maybe with the new one I will be lucky!
Thank you very much for your answers!
