Faccin0
Jul 01, 2019Guide
Remote Management issue
hello everybody, I'm tring to use the remote management but I'm having issue with the configuration. So this is what I did: - created a domain *.mynetgear.com to use DDNS - activated the remote...
- Jul 01, 2019
What always works is the App based (Nighthawk App, Genie desktop App) remote administration access which does not require a public IP direct on the router. Limited functionality, but better than noting.
schumaku
Jul 01, 2019Guru - Experienced User
Faccin0
Jul 01, 2019Guide
The app doesn't work but my phone has also some network problem and I'm replacing it. Maybe with the new one I will be lucky!
Thank you very much for your answers!
