Spiderpan
Mar 28, 2020Aspirant
Remote management still doesn't work
)Due the coronavirus issue I need the remote management of my old but still good D7800 I've read several topis about it so I did everything properly I suppose: update the latest firmaware, factory...
- Apr 01, 2020
> o My router (ADVANCED HOME) says my IP is 100.124.135.89, the same in
> the Android Genie App> Or, plug it/them in at: https://whois.arin.net/ yourself.
Did you try that? It's a shared/private address. More important,
it's different from your apparent public address:> I get 77.32.x.y
Did you try that? It's a public address. But it's not the (WAN)
address of your router.> I tryed usign both the IP to reach the router 100.124.135.89:8483
> 77.32.24.191:8483 but they don't work
That's right. As explained before, "100.124.135.89" is a private
address, so can't work from the outside world. "77.32.x.y" is a public
address, but it's the address of a router at your ISP, not the address
of your D7800.> Strangely I can get the router and the NAS, using their own app like
> genie or dsfinderA device (router, NAS box, ...) which creates an _outgoing_
connection to some cloud server somewhere can be contacted by going
through that cloud server. Using a web browser to create an _incoming_
connection directly to the router requires that the router have a public
IP address.> > You might talk to your ISP, and ask about getting a public address.
> This may be the answerYup.
Spiderpan
Mar 29, 2020Aspirant
so:
- the FW is the last V1.0.1.56
- Yes i'm using dynamicdns by mynetgear
- it works, I tried from another pc with nslookup and with a mobile, connected via 4G they both resolved the correct IP
- As before I tired to manage the router with a laptop or mobile not connected to the D7800 network
Tomorrow I'll try doing another factory reset but this time I'll restore it manually (I'm taking screenshoots of the configuration)
thanks for now. I'll let you know if it works
antinode
Mar 29, 2020Guru
> o Yes i'm using dynamicdns by mynetgear
> o it works, I tried from another pc with nslookup and with a mobile,
How, exactly, did you establish what's "the correct IP"? What's the
top half of it ("a.b" out of "a.b.c.d")?
Does your "the correct IP" match the D7800 WAN/Internet IP address?
ADVANCED > ADVANCED Home : Internet Port : Internet IP Address
The potential threat:
- SpiderpanMar 31, 2020Aspirant
You were right antinode I didn't know the issues behind CGN
The IP from the router was different from the one returned from the no-ip service and the Synology ddns
anyway this time I tried both of the IP but none is working :smileyfrustrated:
xx.xx.xxx.xxxx:8483yyy.yyy.yyy.yy:8483
Somehow I managed to get the genie app working.
it sounds strange but It can help others:
I connected the genie app (android) through the same LAN, I set on the remote management (In the app I mean, even though it was already set in the router configuration). After that the app works even in remote.I solved only half of the problem, for now
- antinodeMar 31, 2020Guru
> xx.xx.xxx.xxxx:8483
> yyy.yyy.yyy.yy:8483> [...] What's the top half of it ("a.b" out of "a.b.c.d")?
Still a mystery.
> [...] I tried both of the IP but none is working
A private address can't work from the outside world. The public
address can't work from the outside world if it's not your router's
WAN/Internet address. You might talk to your ISP, and ask about getting
a public address.- SpiderpanApr 01, 2020Aspirant
I'm sorry but I can't get it, my english has become rusty :smileysad:
I'll try to explain better; for example:
- My router (ADVANCED HOME) says my IP is 100.124.135.89, the same in the Android Genie App
- but when I resolve my two DDNS services xxxxx.mynetgear.com or xxxxx.synology.me , I get 77.32.24.191
I checket it with my.noip.com synology.com dnsqueries dnscecker and even nslookup in the linux terminal
I tryed usign both the IP to reach the router 100.124.135.89:8483 77.32.24.191:8483 but they don't work
I hope I answered your question
Strangely I can get the router and the NAS, using their own app like genie or dsfinder
>A private address can't work from the outside world. The public address can't work from the outside world if it's not your router's WAN/Internet address.
