nodaicrag
May 31, 2017Aspirant
Remote Management
I live abroad and before I left the USA, I turned on remote management on my R6900. I wrote down the Remote Management Address and allowed access by Everyone. I noted the port number too. I also sign...
- Jun 07, 2017
I am now able to connect remotely. I had to just do the same thing as was previously advised from the earlier thread I had posted. I had a friend log into the router and change the LAN IP value to a 3, that is 168.1.3.1 and I am now able to connect remotely from Thailand to use the VPN feature and connect to Netflix.
Here is the solution from a different thread: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/VPN-R7900-Connected-to-home-but-no-internet/td-p/1255169
May 31, 2017Guru - Experienced User
Did the IP address change at the router by chance?
What is the Mfr and model of the ISP modem?
Something to review, you might install teamviewer at the remote site for ease of access to that PC and that PC then can access the router.
