nodaicrag
May 31, 2017Aspirant
Remote Management
I live abroad and before I left the USA, I turned on remote management on my R6900. I wrote down the Remote Management Address and allowed access by Everyone. I noted the port number too. I also sign...
- Jun 07, 2017
I am now able to connect remotely. I had to just do the same thing as was previously advised from the earlier thread I had posted. I had a friend log into the router and change the LAN IP value to a 3, that is 168.1.3.1 and I am now able to connect remotely from Thailand to use the VPN feature and connect to Netflix.
Here is the solution from a different thread: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/VPN-R7900-Connected-to-home-but-no-internet/td-p/1255169
nodaicrag
Jun 01, 2017Aspirant
Thank you. I apologize as I am a novice at networking. Do you mean use XXXXX.mynetgear.com:8443 or https://XXXXX.mynetgear.com:8443?
GearNetRouter
Jun 01, 2017Virtuoso
I'm not familiar with NO IP but it would be whatever you chose as your IP address. So would be the latter.
Example of how I think it should be:
https://YOURNAME.FREEDNS.NO-IP.COM:8443
But check your NO IP documentation or ask them?
