nodaicrag
May 31, 2017Aspirant
Remote Management
I live abroad and before I left the USA, I turned on remote management on my R6900. I wrote down the Remote Management Address and allowed access by Everyone. I noted the port number too. I also sign...
- Jun 07, 2017
I am now able to connect remotely. I had to just do the same thing as was previously advised from the earlier thread I had posted. I had a friend log into the router and change the LAN IP value to a 3, that is 168.1.3.1 and I am now able to connect remotely from Thailand to use the VPN feature and connect to Netflix.
Here is the solution from a different thread: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/VPN-R7900-Connected-to-home-but-no-internet/td-p/1255169
GearNetRouter
Jun 01, 2017Virtuoso
So you should use the hostname you selected and as displayed under the Dynamic DNS tab. If so, I can't explain why it doesn't work. It should.
nodaicrag
Jun 02, 2017Aspirant
I tested and was able to remotely access my parents router I setup in NY. The only things that are different is 1) Time Warner vs Comcast 2) I changed part of the LAN IP (I think it's LAN setting) address to 3, I mean 192.168.3.1 to make the NY VPN to work.
