MaxTH's avatar
MaxTH
Remote Management
I'm using a Netgear R6700v3 router with Windows 8.1 using Chrome. Also iPhone 8 and iPad. I'm attempting to do full remote management as opposed to the Nighthawk app. I have remote management turned...
  • antinode's avatar
    antinode
    May 19, 2020
    > [...] Is this how it's supposed to work? [...]
       I'd say so.  When "only this computer" means "only this IP address",
    and that IP address changes, then it's not seen as the same "this
    computer".
    > [...] I guess I could allow remote access by "everyone" but it doesn't
    > seem like the wise thing to do. [...]
       Choose a good password.
    > [...] Or maybe an IP range but I wouldn't know what range to put in.
       I'd expect that to depend on the ISP in use by the phone.  What are
    some example IP addresses which it has gotten recently?
    > [...] Or else get a static IP address. [...]
       For a phone?  I'd bet against that being possible.
       I suspect that the designers expected the user to have a real
    computer with a fixed (or reasonably limited) IP address.  Or else,
    choose a good password?
