oray
Jan 13, 2022Follower
Remote Management
My model number is R6350. Is remote management no longer available in firmware version 1.1.0.84? Before the update to this version, remote management was possible. After the update the feature is no ...
Jan 13, 2022Guru - Experienced User
Remote Mangagment was removed from NG routers. I believe it may have been due to a security concern. So there using the mobile NH app and Access Anywhere feature on the app to be able to remote in to the router using the Nighthawk app.
Netgear has set up a community forum specifically for Smart WiFi Router products:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
