Batman-15
Dec 16, 2021Tutor
Remove a Device from the Allowed Access List
Good Morning: I really need some help with the following issue: When I go to > Security > Access Control > Allowed devices Currently not connected the network and try to remove a device from by the ...
Peggy75145
Dec 16, 2021Aspirant
Batman-15 wrote:Good Morning:
I really need some help with the following issue: When I go to > Security > Access Control > Allowed devices Currently not connected the network and try to remove a device from by the devices list by check marking the device and select remove from list. it does not remove it, it moves the device six up from it and instead deletes it. Does anyone know how to fix this? Ia it a browser issue? It is really annoying when you are trying to keep your router clean and secure.
Firmware Version: V1.3.3.142_10.1.75
Thanks for any and all help!
Respectfully;
Mark K.
Several comments have been deleted. All were relevant. Why the deletions?
Batman-15
Dec 16, 2021Tutor
Good morning what are you talking about as far as deleting comments I just posted this for the second time!
- DexterJBJan 13, 2022NETGEAR Moderator
Hi Batman-15, may we know if you are still experiencing the issue?
Dexter
NETGEAR Team
- Batman-15Jan 14, 2022Tutor
Yes I am still having the issue. The issue affects the any changes made to the connected llst, the allowed but not connected list and the blocked list. Furthermore the radio setting for allow devices to connect keeps changing by itself from Block all new devices to Allow all new devices.
These issues really need to be addressed.
- DexterJBJan 16, 2022NETGEAR Moderator
Thanks for responding. We'd like to know the following.
1. Does the issue persist with other firmware versions?
2. Have you tried using a different browser/device?
3. Have you tried modifying the setting using Incognito Mode/Private Browsing?
4. Have you tried disabling browser extensions (AdBlock etc.)?
Dexter
