Batman-15
Dec 16, 2021Tutor
Remove a Device from the Allowed Access List
Good Morning: I really need some help with the following issue: When I go to > Security > Access Control > Allowed devices Currently not connected the network and try to remove a device from by the ...
DexterJB
Jan 14, 2022NETGEAR Moderator
Hi Batman-15, may we know if you are still experiencing the issue?
Dexter
NETGEAR Team
Batman-15
Jan 14, 2022Tutor
Yes I am still having the issue. The issue affects the any changes made to the connected llst, the allowed but not connected list and the blocked list. Furthermore the radio setting for allow devices to connect keeps changing by itself from Block all new devices to Allow all new devices.
These issues really need to be addressed.
- DexterJBJan 17, 2022NETGEAR Moderator
Thanks for responding. We'd like to know the following.
1. Does the issue persist with other firmware versions?
2. Have you tried using a different browser/device?
3. Have you tried modifying the setting using Incognito Mode/Private Browsing?
4. Have you tried disabling browser extensions (AdBlock etc.)?
Dexter
- Batman-15Jan 17, 2022Tutor
Thank you for your response. Please see below for my answers and comments:
Q. 1. Does the issue persist with other firmware versions?
A. Yes, this issue has persisted through all firmware revisions.
Q. 2. Have you tried using a different browser/device?
A. Yes and No, I use Safari no JOY! but I will try Firefox and see what happens and let you know.
Q. 3. Have you tried modifying the setting using Incognito Mode/Private Browsing?
A. I will try using a "private" window and Report my results.
Q. 4. Have you tried disabling browser extensions (AdBlock etc.)?
A. I have no ad blockers installed.
Bottom line up front I've tried all your suggestions the issue still persists.
OK Here are the final answers to your questions:
A. Yes and I tried both Safari and Firefox the issue persists.
A. Yes I tried a "private" window with both Safari and Firefox, the issue persists.
- abextraJan 21, 2022Aspirant
So It sound like installing Bata Test v1.3.3.142_10.1.75 Hot Fix on my Night Hawk R6900P is not worth doing maianatnce purposes, anyone recomend a firmware?
Thx.
Batman-15 wrote:Bottom line up front I've tried all your suggestions the issue still persists.
