Paulie1001
Feb 09, 2023Follower
Removed the legacy Time Machine backup feature
I have the R7800, and there is suddenly a new firmware available, but i hessitate to update because the firmware update says: Removed the legacy Time Machine backup feature. I have a Time Machi...
Feb 09, 2023Guru - Experienced User
I didn't ever use the feature but my understanding was it was for connecting a hard drive to the router and using the hard drive as a time machine backup. Don't quote me on that as I'm not an apple guy (even slightly).
So if you have an actual time machine/capsule (?) that is hardwired in via ethernet, you should be fine.
Worse case, make a backup and if it causes issues, you can always downgrade.
