Paulie1001
Feb 09, 2023Follower
Removed the legacy Time Machine backup feature
I have the R7800, and there is suddenly a new firmware available, but i hessitate to update because the firmware update says: Removed the legacy Time Machine backup feature. I have a Time Machi...
michaelkenward
Feb 10, 2023Guru - Experienced User
Not that "suddenly". That firmware is more than three months old.
I recall a few issues reported here.
Search - NETGEAR Communities – Time Machine R7800
It isn't easy to interpret Netgear's release notes. (Nothing new there.) But given the way that Apple does things, it may be that Netgear has removed something that Apple no longer supports.
Remember, installing new firmware isn't a one-way process. If you find that it does break things you can always roll back.
