Zummy
Nov 07, 2021Follower
Repeater 6120
Everything is working but wps button not green. Problem?
- Nov 07, 2021
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extendersIf the extender is working and connected, the WPS button isn't needed. Its only to connect the extender to a wifi router both using the WPS button method. Review the user manual for use and operation of the WPS button.
Thank you.
Nov 07, 2021Guru - Experienced User
Thank you.
