jmunga13
Jan 27, 2021Follower
Repeater mode not available on nighthawk r6900v2
I have been trying to set up my nighthawk r6900v2 router for about 2-3 hours now. I wanted to set put in repeater mode so that I could put it upstairs in my house, but when I go into the routersetup,...
microchip8
Jan 27, 2021Master
NETGEAR's site is outdated. Virtually all routers do not support Repeater mode
You also don't want to use it as it cuts bandwidth in half due to constant need to be in connection with the main roouter. Your best choice is Access Point and pull a wire. If you can't do that, powerline adapters are a good alternative though not as speedy
- michaelkenwardJan 28, 2021Guru - Experienced User
I second that suggestion. Unless you have seriously fast broadband, you won't notice much difference.
On the original question, visit the support pages:
Support | NETGEAR
Feed in the model number and check the documentation for that hardware. It claims that it does support bridge mode. Read the section Set Up a WiFi Bridge Between the Router and Another Device.
They may have removed this feature and failed to update the manual. That wouldn't be unknown.
