rswils76's avatar
rswils76
Initiate
Dec 22, 2021
Repeater or Bridge?
Hello Again,
I posted a discussion yesterday, but I may not have been asking the correct thing here.
I have a R6200V2 and want to simply use it to repeat or extend the current router I have in place.
My question is, is if I set the router up for this initially, will this extend or repeat the signal from the main router without the need of attaching it to a network connection? In other words, can I set the R6200v2 up as a extender and simply plug it in with no cat5 attached to it and will it extend the signal?
Excuse me if I'm mixing up the terminology, extend, bridge, repeater etc....I'm a novice and aren't well versed in routers.
All I want to do is get my WiFi signal to a place just out of range without having to plug it into a network connection if possible.
Thank you,
Ralph
1 Reply
