GGabella
Feb 03, 2021Aspirant
Replace NETGEAR 10 by NETGEAR28
Although I have the proper DSL user name and password, NETGEAR28 does not work
Feb 03, 2021Guru - Experienced User
What actual router do you have?
netgear10/netgear 28 tend to be your ssid name and not your model.
Is it connected to a dsl gateway or whats your whole setup?
- GGabellaFeb 03, 2021Aspirant
Thank you for your answer, and sorry for wrong information…
I am replacingNETGEAR N150 WiFi DSL Modem Router - Essential Edition Model D500orNETGEAR 300 WiFi DSL Modem Router - Essential Edition Model D1500 (both names on the Installation leaflet)byNighthawk Modem/router WiFi VDSL /ADSL AC1900Model D7000v2…- plemansFeb 03, 2021Guru - Experienced User
You might get better assistance in the DSL forum and not the general router forum then
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
did you run the setup wizard?
Or even just copy over the dsl settings from the old router to the new one?
