POS-Guy
Sep 06, 2020Aspirant
Replaced Nighthawk with Nighthawk. Now devices can't see each other.
I recently replaced an older Nighthawk router with a new R7800. I have updated the firmware and performed a factory reset. I was hoping that it would be relatively plug-and-play to remove the old o...
- Sep 08, 2020
Thank you all for the help. I finally got it all working. It appears it was a combination of things. I did have some static IPs that needed changed. I also re-booted everything again, in the right order. (Not sure if this helped, but maybe the second time was the charm.)
For those of you who took the time to offer constructive help, thank you so much.
POS-Guy
Sep 07, 2020Aspirant
Thank you for your help. I have just now powered-down and powered-up everything in the sequence suggested above. Unfortunately, I still don't have access to other devices on the network. I have a Netgear NAS that was mapped to network drives. I have a network printer. All of these things were accessible from my PC before I replaced my old Nighthawk with a new Nighthawk. Now, they are not accessible from the PC.
If that doesn't work, you may have to reset the and reconfigure that modem. It is designed to work in partnership with the router.
I'm not sure that I understand how a change in the router would make it so that the settings of the modem need to be changed in order for my network printer to be seen on the network. If this is the case, does that mean I need to contact my ISP?
I don't understand this bit:
POS-Guy wrote:None of the PCs are connected to the same network switch as the printer, could that have something to do with it?
You are running two separate networks?
I have three NETWORK SWITCHES that are downstream of the router. I'm just grasping at straws here by mentioning that my PC isn't on the same NETWORK SWITCH as the printer. However, it is on the same switch as the NAS, so that doesn't explain my inability to connect to the network drives.
antinode
Sep 07, 2020Guru
> I recently replaced an older Nighthawk router with a new R7800. [...]
Did your (unspecified) "an older Nighthawk router" have a model
number? Did you have address reservations (or other non-default
settings) configured on it?
> [...] on any PC, it shows as offline and I cannot ping the printer.
"cannot" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations. Copy+paste is your friend.
What are the IP addresses of these gizmos?
> My setup is modem->Nighthawk->network switch->printer
What, exactly, is your (unspecified) "network switch"? Where's your
"any PC" in that picture?
That would depend on whether your "network switch" is really a
network switch.
"the same network switch"? How many are there? What, exactly, is
connected to what, exactly? (Hint: If a device has different types of
Ethernet ports, then "connected to device" is not enough detail.)
> You can't just swap out one device for another. Your whole network
> needs to adapt, including the modem.
Nonsense. If your two routers were configured similarly, then they
could easily have been interchangeable. Apparently, there's some
difference between their configurations.
> [...] I have a Netgear NAS [...]
IP address before and after the Great Change?
> so that the settings of the modem need to be changed [...]
In general, it wouldn't.
> I have three NETWORK SWITCHES that are downstream of the router. [...]
"NETWORK SWITCHES" is not a much more detailed description than
"network switch".
If all your devices are on the same LAN IP address subnet, then your
(unspecified) "NETWORK SWITCHES" shouldn't matter. But "ping" should
work from any device on that subnet to any other.
- POS-GuySep 07, 2020Aspirant
Wow.
I came here looking for help, not some condescending diatribe because antinode needs to write something that he can show his friends while he tells them about his "very good brain". If there is critical information that I was unaware was needed, then you could ask clarifying questions, but that would have actually been productive and not nearly as belittling as what you wrote.
I'm not going to dignify your inflamatory rhetoric with any additional response. If someone else wants to offer some help, it will be greatly appreciated. Antinode, if you just want to further pump your own ego, do it somewhere else.
