ramhad3
Jun 29, 2017Aspirant
Replaced older NIGHTHAWK router with a newer one. Can't connect now
Was getting drops in connection from (SUSPECTED) old router. AC1900 Nighhawk. Bought a new one, the AC1900 DST, R7300DST set it up as said by the instructions. Now it wont connect. The WIFI is being s...
- Jul 01, 2017
YEP...
Problem is SOLVED......... Defective router right out of the box... Thanks QA.
I took it back and upgraded to the AC2600 hooked right up no issues.... Who is QA at Netgear....???!?!?!
JamesGL
Jun 29, 2017NETGEAR Employee Retired
Hi ramhad3,
If you connect your computer wired to the R7300 will you get internet connection?
What are the lights on the front panel of the router?
