ramhad3
Jun 29, 2017Aspirant
Replaced older NIGHTHAWK router with a newer one. Can't connect now
Was getting drops in connection from (SUSPECTED) old router. AC1900 Nighhawk. Bought a new one, the AC1900 DST, R7300DST set it up as said by the instructions. Now it wont connect. The WIFI is being s...
- Jul 01, 2017
YEP...
Problem is SOLVED......... Defective router right out of the box... Thanks QA.
I took it back and upgraded to the AC2600 hooked right up no issues.... Who is QA at Netgear....???!?!?!
William10a
Jul 01, 2017Master
The modem is connected to router by a lan cable from the lan port of the modem to he yellow internet port of the router correct ?
What lights are lighting up and what color on the router?
ramhad3
Jul 01, 2017Aspirant
YEP...
- William10aJul 01, 2017Master
I hate when that happens it is the hardest thing to find at first you know the router is new and the network work before you replaced the router so where it did go wrong goes through your head.
All the it is the thing think can not be.
- ramhad3Jul 02, 2017Aspirant
Amen,
I beat my head against the wall for hours cause someone in QA didnt properly test it before the product went out the door.
