TexasIndian
Dec 08, 2020Tutor
replaced router reusable?
Waiting to purchase new AX router "coming soon", which will replace current router. Speaking 'techno-inept', what ALL does it take to: 1. erase existence of current router just before installing ne...
- Dec 08, 2020
If its factory reset, the new user would just need to follow the install guide.
For the R7000, it can be found here:
DarrenM
Dec 08, 2020Sr. NETGEAR Moderator
You will just need to hold the reset button for 10+ seconds on the router. Then they would be able to set the router up like new.
DarrenM
