stevenfry
Aug 27, 2022Follower
Replacement equivalent for Nighthawk X10 AD7200 (R9000) ?
Hi, The fan in my Nighthawk X10 AD7200 Smart WiFi Router (R9000) has failed and I need to buy a new router. Can someone please tell me the current equivalent product from Netgear? I need the faste...
Aug 28, 2022Guru - Experienced User
How much area are you covering?
Are you looking for single router solutions or a mesh solution?
A mesh might be beneficial as then it spreads the load out a bit (if your area is big enough).
Flagship routers: RAXE500 (triband with 6ghz), RAXE300 (triband with 6ghz but a little lower performing), and the RAX200 (triband but 2x 5ghz instead of a 5ghz and 6ghz)
You could look at the mesh systems like the RBKE963 or RBK853
