Issachunt
Dec 29, 2022Follower
Replacement Router for BT Smart Hub 2
Hi looking for a a replacement router to replace the BT Smart hub 2...any suggestions please? Router is FTTP Smart Hub Thank you
Dec 29, 2022Guru - Experienced User
I would also contact the ISP to check to see what they support officially on there network and if there are any requirements.
Thank you
- michaelkenwardDec 29, 2022Guru - Experienced User
That's not how BT works. It wouldn't know a router from its elbow.
- FURRYe38Dec 29, 2022Guru - Experienced User
That bad huh? Wow.
Afraid so. But it does have a reasonably capable user group:
Welcome to BT’s official support community.
It also has its own on-line store, but I wouldn't trust that.
