Issachunt
Dec 29, 2022Follower
Replacement Router for BT Smart Hub 2
Hi looking for a a replacement router to replace the BT Smart hub 2...any suggestions please? Router is FTTP Smart Hub Thank you
Dec 29, 2022Guru - Experienced User
I would also contact the ISP to check to see what they support officially on there network and if there are any requirements.
Thank you
michaelkenward
That's not how BT works. It wouldn't know a router from its elbow.
