OldBob's avatar
OldBob
Luminary
Jan 03, 2020
replacing non-Negear router with app for Model Number R7960P
I have just purchased and am thrilled with the install of the Model Number R7960P Nighthawk router. The best feature was I could rename it with my old SSID and password and it found that network and I...
  • microchip8's avatar
    Jan 03, 2020
    if you set the same SSID and password used on the old, non-NG router on the new NG router, it should work
    Do not use crappy apps. Use the WebGUI at http://192.168.1.1 - especially if you need to do firmware upgrades. Also use wired connection for upgrading
