boudini
Mar 28, 2023Aspirant
RESET ??
What is best route to reset a FORGOTTEN password - user name AND Security questions for NETGEAR ROUTER. ?? I feel my NETGEAR router has PLEASE REPLY paul.boudin@yahoo,com
Mar 28, 2023Guru - Experienced User
You could simply try pushing and holding the reset button for 7-15 seconds while its powered on.
then you'll be able to reinstall it.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
boudini
I know it was a silly question.
I may call another authority and inquire :
We have a BnB within our home and want guest totally separate from the wife and I private setup.
( SEPARATE PW's )
Plus
I have WYZE security and the cams only run on 2.4 gig
But
We want to surf and use the 5 gig for our needs.
Would you have a very brief suggestion ??
- michaelkenwardMar 29, 2023Guru - Experienced User
You own some Netgear equipment that you want to set up?
What is it?
Follow the device from plemans and read the manuals.
Start with the basics and then move on to solving your problem.
- plemansMar 29, 2023Guru - Experienced User
Without knowing what your device is, its tough to recommend if you need a different router or use the guest network on your current one.
IF your router supports it, you could use the guest network for the bnb guests.
If it doesn't have one, an investment in buying a business class router that supports separate ssid/vlans might be worth it. Then you could have separate networks
