boudini
Mar 28, 2023Aspirant
RESET ??
What is best route to reset a FORGOTTEN password - user name AND Security questions for NETGEAR ROUTER. ?? I feel my NETGEAR router has PLEASE REPLY paul.boudin@yahoo,com
boudini
I know it was a silly question.
I may call another authority and inquire :
We have a BnB within our home and want guest totally separate from the wife and I private setup.
( SEPARATE PW's )
Plus
I have WYZE security and the cams only run on 2.4 gig
But
We want to surf and use the 5 gig for our needs.
Would you have a very brief suggestion ??
michaelkenward
Mar 29, 2023Guru - Experienced User
You own some Netgear equipment that you want to set up?
What is it?
Follow the device from plemans and read the manuals.
Start with the basics and then move on to solving your problem.
