Twoface1569
Jun 02, 2022Follower
Reset genie
So I bought a used router from some one and they never reset the netgear genie password. How can I reset this with out the old user info
Factory reset it.
push and hold reset for 7-15 seconds while powered on.
that should get you back to factory settings.
default login: admin
default password: password
