lnardone
Mar 23, 2021Follower
Reset My Password on my Netgear
Good Morning, I would like to know how to reset my password on my netgear Router. Thank you Lillian
antinode
Mar 23, 2021Guru
> Model: R6020|AC750 Dual Band WiFi Router
Is that accurate? Firmware version? Connected to what?
Which "my password"?
You might try an oft-neglected resource:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Types of Logins", "Basic WiFi Settings", "Factory Default Settings",
and/or "Reset button". Further reading might not hurt, either.
