lgkeys
Aug 13, 2021Aspirant
RESET NAME of Modem
Solar people shut down power for a few seconds and when power back on, my Netgear Nighthawk went back to factory setting, name and password. Not what I had set it up to show for Internet Name or Pas...
michaelkenward
Aug 14, 2021Guru - Experienced User
That's not normal. Power cuts do not usually erase your settings.
lgkeys wrote:
How do I change it back to the way I had it??
If you saved your configuration, then you can restore that.
Failing that, just set it up again.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
You might get more help of you told people what your device is.
Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
That's not a router.
lgkeys
Aug 21, 2021Aspirant
Thanks, but I actually found someone who could help me. It's all in the IP address on the modem itself. That's how you chg your settings, passwords.
- michaelkenwardAug 21, 2021Guru - Experienced User
I'm glad it worked out but the explanation you got is strange and might not help anyone who tries to follow that advice. They would do well to ignore it.
lgkeys wrote:
It's all in the IP address on the modem itself. That's how you chg your settings, passwords.There can be several "IP addresses" on the modem. The one that the network has on your local network, which can depend on the hardware you own. Then there is the IP address that your ISP hands out for the internet.
I suspect that the one you were told to check is the one mentioned here:
If you cannot login to your router | Answer | NETGEAR Support
You never got round to telling us what this modem is. (Your footer refers to a USB adapter, which will get you nowhere.) The IP address that the modem gets depends on the device in question. For example cable modems aren't usually the same as DSL modems.
The next time you run into a problem, start with the manual.
Support | NETGEAR
Begin with the Quick Start/Installation Guide.
