Sarge34
Apr 04, 2021Guide
Reset password and user name on www.routerligin.net
I purchased a Netgear R8000 router that was used. I was able to register it wtih Netgear and I want to see if I need to upgrade the firmware. I go to www.routerlogin.net and found the default user ...
antinode
Apr 05, 2021Guru
> If there a way I can reset www.routerlogin.net back to default [...]
Here's a radical concept which works for some people:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Reset" and/or "Factory Settings". Further reading might not hurt,
either.
- Sarge34Apr 16, 2021Guide
ANTINODE... when I first read your hideous comment I just chocked your mentality up to being a dim lightbulb. I do not appreciate that language used and would appreciate it if you would simply refrain from making such rude and vulgar comments. You see, my grandson was sitting on my lap when I opened up your reply. Thank much for subjecting him to your rude and distasteful comment.
- microchip8Apr 16, 2021Master
There's a Reset button at the back of the router. Push it in for 5-10 seconds and release
- Sarge34Apr 16, 2021GuideThank you for your reply... I have reset the router but it won't reset, http://www.routerlogin.net/. The former owner set their log in at the website and I can't get in touch with the former owners.
