Sarge34
Apr 05, 2021Guide
Reset password and user name on www.routerligin.net
I purchased a Netgear R8000 router that was used. I was able to register it wtih Netgear and I want to see if I need to upgrade the firmware. I go to www.routerlogin.net and found the default user ...
michaelkenward
Apr 18, 2021Guru - Experienced User
Sarge34 wrote:
You are so correct. It is very confusing and makes no sense.
I'm sorry about that, but there are some things that take a bit of understanding. Eventually, you have to do some homework and not expect people to explain things over and over again.
Did you try the advice that microchip8 suggested? That would be a good place to start.
Sarge34 wrote:
YOu wrote, "There is no "website" where anyone can set a passwords" I'm not sure what you mean when you say "where anyone can set a passwords"
It means what it says.
You seem to think that there is a website somewhere that the previous owners have created some passwords. There isn't. The rest follows. If there is no site on the world wide web, there is nowhere out there to reset passwords. You do that by following the advice from microchip8
Have you done the basics? Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You may have done this already. I can't tell from your message.
Sarge34 wrote:
What are you talking about when you say "passwords" as in plural?
Netgear makes life interesting by having all manner of passwords. There is the one into the router's controls, then there are those to get into the router's wifi, and then there any that you use to get into this Community and/or MyNetgear.
Different passwords pop up at different times, depending on how you connect to the device and where you are trying to access from, your local network or somewhere else on the Internet. (Previously known as Remote Access, that's now called Anywhere Access.)
If you are talking about access to the browser's graphical user interface (GUI), the router's controls, these are on the label for your device, along with the default wifi login details. The username is fixed at admin. The default password is password.
If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. (See above.) Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
antinode
Apr 18, 2021Guru
> [...] There is no "website" where anyone can set a passwords. [...]
> https://community.netgear.com/t5/x/x/m-p/2073737#M187301
> [...] It is very confusing and makes no sense. [...]
Some (confused) people seem to enjoy propagating their own confusion.
In reality, using rational definitions, it's pretty straightforward.
- microchip8Apr 18, 2021Master
Instead of routerlogin.net you can use http://192.168.1.1 - it's the same thing and will take you to the Web UI of the router. If that doesn't work because the router is using a different address (as is the case if it's connected to another router/gateway) you can try http://10.0.0.1
routerlogin.net is not really a "site". It's just an URL used to login into the Web UI of the router.
Also, a reset is done with the button at the back while the router is powered on. As I mentioned, hold the reset for more than 5 seconds then release. That will restore all settings to their defaults and you should be able to login at one of the above addresses using the default password/username
- antinodeApr 18, 2021Guru
> routerlogin.net is not really a "site". It's just an URL [...]
Look! There's another one.
And to what, exactly, does a URL (_any_ URL, beginning with
"http[s]://") point, if not a web site? It's pretty much the
definition.https://en.wikipedia.org/wiki/URL
I'm still waiting for anyone to explain how this false distinction
improves anyone's understanding of anything. Apparently all too
relevant:https://timharford.com/2021/03/cautionary-tales-the-dunning-kruger-hijack/
