JGelon's avatar
JGelon
Reset port forwarding to release port 80
I was able to set port forwarding on my nighthawk. However I made the mistake of using port 80 and so I can't access the admin UI anymore. Is there a way to access it again, hopefully without resetti...
  • JGelon's avatar
    JGelon
    Apr 09, 2020
    Apparently a reboot of the router already did the trick to revert the change of port 80.
