OBoy
Jul 10, 2021Tutor
reset remote
Trying to reset router remotely. I have password but when I enter admin and the password it takes me to a screen asking for the router serial number not to a reset option. I dont have the serial #...
DarrenM
Jul 12, 2021Sr. NETGEAR Moderator
Have you tried using the Nighthawk app?
DarrenM
OBoy
Jul 13, 2021Tutor
when I use app on my phone on T-Mobil it says R7000 Disconnected and list serial #
- antinodeJul 13, 2021Guru
"Trying" _how_, exactly? Why? Did it stop working properly?
> [...] when I enter admin and the password it takes me to a screen
> asking for the router serial number not to a reset option."enter admin and the password" into _what_? What, exactly, are you
doing, from what, where, connected to what, how?Generally, these routers ask for a serial number as part of a
password-recovery scheme (which does not always work). Which suggests
that you're providing a bad password.
> when I use app on my phone [...]Have you used "app" successfully before?
- OBoyJul 13, 2021Tutor
Using Nighthawk app on phone was trying to access my R7000.
I am at a remote location on T-Mobil network not home wo-fi.
Says wifi not detected so I tap connect via anywhere access.
Header comes up says Your Product
below shows pic of router and a red dot next to R7000
Says Disconnected
and list serial # of unit
If I touch the red tot reply at bottom of phone screen says Device is Offline.
Can not do anything else.
