Kyra1
Jun 22, 2022Aspirant
Reset to Default Settings
Was having a problem with mu NightHawk router. i contacted IT and was to to reset the router and change the SSDI and password which did not solve the problem. So I am wondering if there is a way t...
michaelkenward
Jun 22, 2022Guru - Experienced User
Kyra1 wrote:
So I am wondering if there is a way to reset to the original settings.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
