Twon1926's avatar
Twon1926
Follower
Jan 30, 2021
Reset to factory, stops working shortly after
Performed a factory reset.
Only entered in new admin account password. Left everything else set to factory settings. Works, everything seems to be working. Within 10 minutes internet no longer working. Cannot access the setup page via ip, or host.
I did connect directly to modem. Computer works perfectly. When I am connected to the router I am using the enternet connection to take wifi out from being the issue.
Thoughts?
1 Reply
  • plemans's avatar
    What modem is it connected to?
    What firmware are you on?
    What are all the lights on the router doing? (color/blinking/etc)
    are you able to ping the router?
