nich1982
Jun 26, 2023Aspirant
Reset unsuccessful
I was out of the house for a month and came back to the wifi network being down. I've reset both the modem and the router, both listed as associated products, multiple times. My network is not disco...
- Jun 27, 2023
nich1982 wrote:
I will probably call Netgear support tomorrow, if that's a thing that exists *shrugs* I've put zero effort, to this point, into finding out if that's a thing or not
Whatever you do, do not call any alleged Netgear support site that find with a web search. They are invariable scams.
For reliable help go through the official support channels and be prepared to pay. Free support is for the first 90 days after purchase.
The official support channels start here:
Contact Us | Support | NETGEAR
michaelkenward
Jun 26, 2023Guru - Experienced User
nich1982 wrote:
I was out of the house for a month and came back to the wifi network being down. I've reset both the modem and the router, both listed as associated products, multiple times. My network is not discoverable on any device and it is not recognized by the Nighthawk app.
It sounds like the modem is working as expected.
As you have reset the router – why did you do that? – you'll have to set it up from scratch.
Remember to do this in the correct order.
As this is a router, there is probably a modem sitting in front of it. You need to get the devices to forget any inherited settings. Among other things, that means rebooting the network.
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
If that doesn't mend things, you'll have to tell us a bit more about what happens.
What do you mean by "network is not discoverable on any device"?
You can't plug into a LAN port and connect? What happens when you try?
You can't see any wifi SSIDs? You can see them but can't connect? What happens when you try?
In general, it isn't usually the best strategy to use an app to set these things up. That's a dumbed down way of doing things. Experienced users prefer the browser graphical user interface (GUI). logging in with routerlogin.net.
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
The manual for your router also explains how to go about this.
nich1982
I'm thinking I'll have to set it up from scratch, I'm not quite sure how to do that. Here's what I did since the last post.
1. I tested to see if internet signals were being sent along the wired route instead of the wireless. There were no internet signals coming from the router. So the communication between the modem and router is broken somewhere, best guess. *shrugs*
2. I connected my computer directly to the router and navigated over to routerlogin.net and followed the genie, knowing full well I have no idea what I'm doing otherwise. I fell into some kind of loop. See below
tried the setup genie
Prompt 1: Hey, there's no internet connected, try the power cycling the modem or properly connecting the ethernet cord from the modem to the router.
Tried both options, when the 'site' checked for connection again, nothing.
Tried the "none of the above" option, led me to
Prompt 2: 1. fixed IP (I think it was IP anyway) Address (super rare) or 2. not or 3. don't know, choosing either not fixed or don't know I was asked to type in the MAC of the last router that successfully connected to the internet. So I typed it in, clicked next, it tried "Appplying Internet Connection Settings", unsuccessfully, then looped back to first prompt
