nich1982
Jun 26, 2023Aspirant
Reset unsuccessful
 I was out of the house for a month and came back to the wifi network being down. I've reset both the modem and the router, both listed as associated products, multiple times.  My network is not disco...
- Jun 27, 2023
nich1982 wrote:
I will probably call Netgear support tomorrow, if that's a thing that exists *shrugs* I've put zero effort, to this point, into finding out if that's a thing or not
Whatever you do, do not call any alleged Netgear support site that find with a web search. They are invariable scams.
For reliable help go through the official support channels and be prepared to pay. Free support is for the first 90 days after purchase.
The official support channels start here:
Contact Us | Support | NETGEAR
nich1982
I'm thinking I'll have to set it up from scratch, I'm not quite sure how to do that. Here's what I did since the last post.
1. I tested to see if internet signals were being sent along the wired route instead of the wireless. There were no internet signals coming from the router. So the communication between the modem and router is broken somewhere, best guess. *shrugs*
2. I connected my computer directly to the router and navigated over to routerlogin.net and followed the genie, knowing full well I have no idea what I'm doing otherwise. I fell into some kind of loop. See below
tried the setup genie
Prompt 1: Hey, there's no internet connected, try the power cycling the modem or properly connecting the ethernet cord from the modem to the router.
Tried both options, when the 'site' checked for connection again, nothing.
Tried the "none of the above" option, led me to
Prompt 2: 1. fixed IP (I think it was IP anyway) Address (super rare) or 2. not or 3. don't know, choosing either not fixed or don't know I was asked to type in the MAC of the last router that successfully connected to the internet. So I typed it in, clicked next, it tried "Appplying Internet Connection Settings", unsuccessfully, then looped back to first prompt
michaelkenward
Jun 27, 2023Guru - Experienced User
- nich1982Jun 27, 2023Aspirant
I appreciate your time, patience, and effort in helping michaelkenward.
