ksov's avatar
ksov
Reset wifi password
I am trying to re-set wifi password.  I type in new password and click save then message is:  The Router could not apply your new settings.   Check your WiFi connection and try again. Not sure what ...
  • ksov's avatar
    ksov
    Sep 17, 2023
    rouuterlogin worked.  Thank you very much for your help.  It was super twisted between the router password and the wifi password.  All is worked out.
