ksov
Sep 10, 2023Aspirant
Reset wifi password
I am trying to re-set wifi password. I type in new password and click save then message is: The Router could not apply your new settings. Check your WiFi connection and try again. Not sure what ...
- Sep 17, 2023
rouuterlogin worked. Thank you very much for your help. It was super twisted between the router password and the wifi password. All is worked out.
Sep 16, 2023Guru - Experienced User
Any progress on this?
Not sure what to do. I am on my phone trying to make this change and the phone is connected to the WiFi with old login. So there is a connection.
- ksovSep 17, 2023Aspirant
I have a chrome book with no way for ethernet. Having my nephew come help later with his laptop. No progress yet. Thank you.
- michaelkenwardSep 17, 2023Guru - Experienced User
You may be able to access the controls on the device using a browser on the Chrome Book.
Same trick that you would use with a wired connection. Aim it a routerlogin.com and see what happens.
