ksov
Sep 10, 2023Aspirant
Reset wifi password
I am trying to re-set wifi password. I type in new password and click save then message is: The Router could not apply your new settings. Check your WiFi connection and try again. Not sure what ...
- Sep 17, 2023
rouuterlogin worked. Thank you very much for your help. It was super twisted between the router password and the wifi password. All is worked out.
michaelkenward
Sep 17, 2023Guru - Experienced User
ksov wrote:
I have a chrome book with no way for ethernet.
You may be able to access the controls on the device using a browser on the Chrome Book.
Same trick that you would use with a wired connection. Aim it a routerlogin.com and see what happens.
ksov
Sep 17, 2023Aspirant
- michaelkenwardSep 17, 2023Guru - Experienced User
Glad that worked out, and that you could follow the skimpy description.
Sadly, it isn't something that Netgear talks about in its rush to send everyone down the app route. And that, as we know, means you can' control a lot of stuff.
