PapaShift
Feb 28, 2022Follower
Resetting R8000
I am wanting to reset my R8000 because i cannot log into my admin because I forgot my password and login info. If I reset the router it will reset all setting I get that but I can not find the origi...
michaelkenward
Mar 01, 2022Guru - Experienced User
PapaShift wrote:
.... I can not find the original pass word and log in name that it comes with. The sticker that has the log in info.
The second sentence doesn't make sense. (Actually, it isn't a sentence.) Are you saying that the label is not on the router? If so, plemans has given the only option.
The default wifi password was on that label. If you can login to the browser graphical user interface (GUI) the wifi password is visible.
