themaadrhetoric
Jul 01, 2021Aspirant
resetting wifi password w/o admin
I forgot my wifi password/can't locate it, I've tried following the link from the main netgear website for reset but the link (routerlogin.net) requires me to log in as admin, which I can't do, becau...
microchip8
Jul 01, 2021Master
If you forgot your admin login password, your only option is to factory reset the router (press for 7-10 secs the reset button at ther back of the router). Password recovery in NG routers has a circular bug that sends you at the beginning even if you entered the right answers.
themaadrhetoric
Thanks
